Idler Pulley?? (Shoebox)?
Old May 16, 2003 | 10:57 AM
mrz28M6's Avatar
Shoebox i know we were trying to figure out the loud noise that was coming from the alternator area, i figured out that its the idler pulley. How hard of a job is this? Could you give me some detailed instructions. I would greatly appreciate it!
Old May 16, 2003 | 11:25 AM
Can't be any harder than the one I just replaced on my wife's Grand Prix. Remove belt, unbolt pulley (13mm), take it with you to the auto parts store to make sure you get the right replacement, return with pulley, bolt it back on, re-install belt.
Easy to get to this stuff with the car up on ramps. Go from underneath.
Old May 16, 2003 | 11:40 AM
mrz28M6's Avatar
Ok thanks for all your help, the only thing i was worried about was is if u needed a special to tool to get the pulley off, i know some cars you need a special tool to get the pulleys off.
Old May 16, 2003 | 12:02 PM
Don't think anything special is needed.
Old May 16, 2003 | 12:20 PM
anasazi's Avatar
2 bolts, fits into place perfectly. even my sister could have replaced that thing... i think it was the easiest repair i've done so far
Old May 16, 2003 | 12:24 PM
You replaced the whole tensioner? I was thinking you could just replace the pulley.
Old May 16, 2003 | 12:42 PM
anasazi's Avatar
nope, all one unit. its not very expensive if i recall correctly
Old May 16, 2003 | 12:53 PM
Bralgar's Avatar
heh, idler pulley and tensioner assem. get interchanged incorrectly around here, huh Shoebox? But since the LT1 has no idler (unless it is has the 1LE AC delete) we can assume he ment the tensioner. But I have a feeling Shoebox was making that point.
Old May 16, 2003 | 12:54 PM
turbo_Z's Avatar
i have one that im sure isnt shot. i believe i have the entire assembly too but i think youd just need the pulley. shoot me a PM if you are interested.
Old May 16, 2003 | 01:03 PM
anasazi's Avatar
bleh now i'm confused... i'm talking about the spring loaded thing on the bottom of the engine that you push down with a wrench to remove the belt.
Old May 16, 2003 | 01:39 PM
Bralgar's Avatar
The tensioner IS the spring loaded thingy on the bottom. It is sold only as an assembly, not just the pulley by itself, as far as I know. I'm pretty sure the pulley is considered non seviceable so you can only get it as a unit with the bracket/spring housing. unconfused?
Idler pulleys are stationary pulleys, no springs, they just.....idle.
Old May 16, 2003 | 02:08 PM
klr96SS's Avatar
Easy to change, be carefull though, I got a tensioner assembly from Autozone and the pulley was larger then stock, So I needed a new belt. It also made a lot of noise, it did last until I could track down a GM unit.
Old May 16, 2003 | 04:24 PM
Yeah, they are two things. However, on my wife's GP, you can replace the pulley separately from the tensioner. That is what I was thinking initially. Guess that threw things off a little. I have not replaced mine yet.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
gelbza
Jul 12, 2015 08:10 AM
