Idleing Issue Please help
Old Apr 3, 2007 | 09:26 PM
chrp3rd's Avatar
Ok car has Mods listed in sig and i am haveing a problem with idle when i start the car up it try's to die and then the IAC catches it. even when its warmed up if im cruiseing at any speed and at WOT its fine actually very smooth but when I take it out of gear and hit the brakes it wants to stall and sometimes it does stall. the only codes I had were a random cylinder misfire which my tuner says thats because of the cam ( im still running OBDII ) and Bank 1 sensor 1 which is the driverside front was bad so I replaced it and it still has this problem, I also checked for vacuum leak and found nothing I even adjusted the idle screw all the way and nothing so PLEASE help for the love of God
Old Apr 3, 2007 | 09:54 PM
OBE1 95Z28's Avatar
Could have a dirty or faulty IAC.
Old Apr 3, 2007 | 10:06 PM
chrp3rd's Avatar
wouldnt that throw a code or something
also I just bolted the iac right up to the new throttlebody and someone said that it wasnt that easy
Old Apr 4, 2007 | 07:52 PM
chrp3rd's Avatar
Anyone Please help
Old Apr 4, 2007 | 08:17 PM
firebird84's Avatar
Im not positive but i have seen some things about the aftermarket throttlebodies do not idle very well because of the size of the idle air passages. and two your iac can fail and not through a code all the computer knows is that it is telling the iac to do something but it might not do it. and it also could just be dirty i would replace the iac with a new one and see.
Old Apr 4, 2007 | 08:50 PM
chrp3rd's Avatar
The Iac Is Only A Couple Of Months Old And I Checked It Anyways And Its Clean I Cant Find Any Vacuum Leaks I Dont Know Maybe Its The Tune But The Guy That Did It Is Very Reputible And Did My Last Car And It Was Fine And It Had Twive The Mods
Dark Zeiro
Mar 11, 2015 07:15 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
