Idle surge
Old Aug 6, 2003 | 01:07 PM
dogboy's Avatar
Idle surge
I did a search on this subject & it seems extensive. I have the problem in drive , while warm. it will idle at 550rpm stumble slightley like it has a mild cam than jump to 800-1000rpm's & than back & so forth. I cleaned out the TB, IAC, new gaskets, Cleaned EGR. Still surgeing but not as bad as before . Also how long does it take for the pcm to relearn idle
Old Aug 6, 2003 | 07:03 PM
yorkie's Avatar
bad iac??
ttt
Old Aug 6, 2003 | 07:35 PM
mirroredfire2's Avatar
check out some of the other hesitation/idle posts.. its very common and very hard to diagnose/fix from what ive seen.. and i have the same problem that you do..
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Double aught
Oct 2, 2015 11:29 PM
KYWes
Sep 26, 2015 08:49 AM
tdigger9899
Sep 7, 2015 10:56 AM
