idle stalling
Re: idle stalling
Originally Posted by OBE1 95Z28
IAC fully open (trying to provide more air) will read 0 counts. This does not tell you that the IAC actually moved or if the passages are clogged up.
160 is bad because the motor wants more air but the IAC cant open any further so it will stall like you are describing. Lubing the IAC could help but ultimately you will just have to crack the TB blades a little... get it to where the IAC will read in the mid 50's.
