idle question for gm847
Old Feb 15, 2006 | 12:15 AM
TransAm396's Avatar
what should I have it set at when I get it programmed? Whats the lowest you should set it at(I want it to have a mean idle..but not be bad for the car)
Old Feb 15, 2006 | 01:05 AM
Brettinator's Avatar
Re: idle question for gm847
900 to 1000 rpm works good, depends on the rest of your setup too of course, but that's a good starting point.
Old Feb 15, 2006 | 01:11 AM
TransAm396's Avatar
what do you mean depends on the rest of the setup? Can it be set to 800? and still run alright?
Old Feb 15, 2006 | 04:39 AM
Silvershark's Avatar
Mine is set at 925.
Old Feb 15, 2006 | 05:59 AM
bowtieman_racin's Avatar
mines about 750-800 sounds great!
Old Feb 15, 2006 | 11:06 AM
TransAm396's Avatar
bowtieman...got a video of it? i wanna hear it..you too silver shark..also...BTman...does it stall ever? I wouldnt mind setting mine at 750 I just dont wanna have to keep my foot on the gas.
Old Feb 15, 2006 | 05:26 PM
I think running a cam at a low rpm like that isnt such a good idea. Running a car bad on purpose... Just doesnt sound like a good idea.
go to the link in my signature and click on videos on the site. There should be an idle vid.
Old Feb 15, 2006 | 10:27 PM
TransAm396's Avatar
ok then..850
Old Feb 15, 2006 | 10:28 PM
TransAm396's Avatar
the vid didnt work.
Old Feb 15, 2006 | 10:54 PM
I dont see where it hurts anything the old small block chevys were all around 750-850 and thats what theyr supposed to be set at. I dont have any problems with it I wish I had a video of it but it sounds great the 112 lobe separation kinda makes it a fast lope but its still awesome. the only problem I have with mine and I only have a base tune so the problem might go away after tuning, is if I go to start it and let off the key to soon before it starts sometimes itll flood a little and I'll just hold the pedal to the floor to shut off the fuel and itll start right up. But I also have 42 lb injectors which are a little big for what Ive got done.
Old Feb 15, 2006 | 11:22 PM
TransAm396's Avatar
oh..anyone got a vid?
Old Feb 16, 2006 | 02:56 AM
atljar's Avatar
Mine.
http://www.s89572780.onlinehome.us/idle.wmv
Been awhile, but I think it was ~900-950
Old Feb 16, 2006 | 03:32 AM
95ttoplt1's Avatar
mine idles nicely at 850-900
no stalling, stock injectors and 3k stall 3.23
Old Mar 4, 2006 | 12:16 AM
TransAm396's Avatar
im setting it at 875
Old Mar 4, 2006 | 11:44 AM
med_reject's Avatar
mine would idle even at 500, but it sounded crappy. I think 900 was a good setting and 800 gave it a lot of lope, sounds more badass to me, and it was no where near stalling. I wouldnt go any lower than 800.
