idle motor control part#?
Old Jan 14, 2004 | 09:01 AM
MattysTA's Avatar
Anyone have the part number for it? im hoping it will help fix my stumble at idle. thanks.....
Old Jan 14, 2004 | 09:17 AM
IAC for a 1997 is GM p/n 17113188. I would make sure it and the passages don't need cleaning, first. Also look for any tears in your intake elbow or any loose or cracked vacuum lines.
Old Jan 14, 2004 | 09:23 AM
MattysTA's Avatar
thanks for the number shoebox,the elbow is no concern(i have the vortech elbow ) and i have not found any vacuum leaks, but i am going to hook up my vacuum guage to make sure,will it be low with the intake leak? cause i know mine is leaking anys i think ill just change it since i had it out a few months ago while swapping the throttle bodies and cleaned it then. it does have 93,000 on it
Old Jan 14, 2004 | 09:26 AM
MattysTA's Avatar
WOW i just priced it at gm parts direct, is that right? 104 list and gmpartsdirect 52bux?? dyaam......
Feb 14, 2015 01:40 PM
Fatdog2
Feb 13, 2015 08:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
