idle and hesitation
Old Nov 16, 2003 | 01:34 PM
CodysRedZ's Avatar
idle and hesitation
For awhile my car has been running a little rough at idle. The rpms arent jumping around but you can feel it when you are at a stand still. Almost like what a larger cam would feel like almost. Every once in awhile too there will be a hesitation when i give it gas from a stop. I know this could very well be the opti going bad( i have 88k miles on her) but before i change that out, what are any other posibilities what it could be? Anything. I have change the plugs and wired and coil a year ago, so i dont think that any of those would be it.
Old Nov 16, 2003 | 01:37 PM
b-stevens's Avatar
Well I changed my plugs about a year ago, and I just replaced them again this week and It runs alot better, even with the gasket leak on the passenger side header.
Before when I would be driving right before it shifted it would hang for like 2 to 4 seconds, now it doesnt do that at all.
Old Nov 16, 2003 | 05:54 PM
CodysRedZ's Avatar
anyone else
Old Dec 7, 2003 | 01:42 AM
1FstFormulaV8's Avatar
I have the same problem these parts have been replaced.
O2 Sensors.
ECM
Plugs
OptiSpark
Fuel Filter
PCV Valve.
Still no change.
Old Dec 7, 2003 | 02:21 PM
slopokrodrigez's Avatar
Check the EGR for sticking or the pintle not fully seating. You can remove and block the vac line to see if it clears up. When the engine is cool, try moving the diaphragm by hand and see if it feels rough. You can also clean it after it is removed.
The best thing to look at is the IAC motor. My truck had a rough idle and I removed and cleaned and reseated it and the thing idles like glass. It had a ridge of carbon build up around the pintle and would not seat properly. I seriously doubt you have an idle issue from the opti.
Old Dec 7, 2003 | 02:35 PM
HBHRacing's Avatar
Agreed on the EGR and IAC..
you can also clean out the TB as well.
Old Dec 7, 2003 | 09:15 PM
AxeGrinder30thZ's Avatar
Check the TB and TB cable. Very overlooked and could cause the symptoms you are saying. The hesitation will suck majorly if the cable is streched far enough. Just ask me... I'm in the process of getting mine replaced now. It's so bad, I don't even know how the TB is opening. Sometimes when I crank the car, it won't even jump past 1k.
Nayr
Mar 3, 2023 08:34 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
tdigger9899
Sep 7, 2015 10:56 AM
techstar
Aug 6, 2015 11:20 AM
