Idle dropping when approaching a stop?
Old Aug 20, 2006 | 02:05 PM
supercharged87's Avatar
Everytime I come up to a stop, and I hold the clutch in and step on the brakes, the idle drops down to 500 RPMs or lower and wants to die. With the air on its worse and it does die sometimes. The car never used to do this, it just started doing this. I took the car apart a few weeks ago to change valvesprings, and ever since I got it back together its been doing this. There are no codes present and everything seems to be okay otherwise. Any one else experience anything like this, or know of a solution to it? It seems like it could be the TPS, but with no code, I don't want to just change it. Thanks in advance for any help.
Old Aug 20, 2006 | 02:28 PM
huskersZ's Avatar
Re: Idle dropping when approaching a stop?
reset the computer by disconecting the battery for about 30 mins. See if this helps. If that doesnt work, use the procedure to reset the IAC motor...use the search function on the board for this easy procedure. Mine has done something similar to that back in the day, and the computer reset took care of it
Old Aug 20, 2006 | 03:11 PM
I'll give it a shot, thanks.
Old Aug 20, 2006 | 04:04 PM
ulakovic22's Avatar
If that doesn't work, just adjust the idle screw on the driver side of your TB until it goes away.
Old Aug 20, 2006 | 04:13 PM
Joe B's Avatar
Also (along with the other comments) make sure that your IAC spring isn't all gummed up....spray it out with some cleaner if it is.......also, if your running a throttle body air foil, which is kinda in the way of your existing IAC bypass hole, it "many times" helps to inlarge the hole a little, like a couple drill bit sizes over what it was from the factory......Joe
Old Aug 20, 2006 | 05:15 PM
OBE1 95Z28's Avatar
Check for vacuum leaks.
Old Aug 20, 2006 | 06:50 PM
30696bird's Avatar
Make sure the MAP sensor did not come loose.
Old Aug 20, 2006 | 08:56 PM
I noticed that the IAC count was up kind of high (75), so I turned the srcew out until it was at about 40 at idle, and brought the TPS volts back down to .69 and unplugged the battery for 10 seconds then did the IAC reset and it seems to be okay now. Thank you everyone for your help.
KYWes
Apr 15, 2015 05:48 AM
ChrisFrez
Mar 22, 2015 07:00 PM
MattFick
Feb 15, 2015 10:16 PM
edman
Jan 25, 2015 02:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
