idle on decel
Old Jun 26, 2004 | 11:34 AM
simple's Avatar
idle on decel
lately when coasting to a stop in neutral my idle will climb up to about 2100 rpm and just hover there for a bit then will finally drop down to 1000rpm after i've sat stopped for a few seconds
what could be some culprits of this?
intake leak....?
Old Jun 27, 2004 | 06:47 PM
simple's Avatar
anybody?
Old Jun 27, 2004 | 06:48 PM
Mystic97Z's Avatar
this has happened to me also, but very few times.
i don't know what causes it either..
Old Jun 27, 2004 | 06:59 PM
Spinner's Avatar
Momentum?
Old Jun 27, 2004 | 07:07 PM
simple's Avatar
Originally posted by Spinner
Momentum?
ummm no
it drops down to normal idle of 1000 or so then climbs back up out of nowhere, not from momentum
Old Jun 27, 2004 | 07:10 PM
Spinner's Avatar
Originally posted by simple
ummm no
Ah. I thought you were talking as if you threw it into neutral from a roll. My car will creep up a few hundred rpms when I do that. I guess from the instant load being taken off of the engine. Sounds like a strange problem though, maybe a problem with extra fuel in the cylinders?
Old Jun 27, 2004 | 07:18 PM
simple's Avatar
well also when in gear the car will pull itself along at about a constant 2000rpm instead of decelerating
i can stay in gear and be on a street doing 30mph, giving it no gas but it will stay at about 2000rpm instead of slowly shaving off speed like it normally should...
Old Jun 27, 2004 | 07:24 PM
Spinner's Avatar
Which leans toward a problem with your TPS
Old Jun 29, 2004 | 01:47 AM
simple's Avatar
TTT
TPS is on the list, anything else i should be checking?
Old Jun 29, 2004 | 02:47 AM
Rodrigues's Avatar
The PCM has tables for iac stepdown which is designed to keep vacuum to the engine while your moving for brakes. When your stopped do the rpms come down quicker?
Old Jun 29, 2004 | 01:46 PM
IslandZ's Avatar
Clean out your IAC, it is supposed to let a little more air in the engine while idling or when you let off the throttle.
Old Jun 29, 2004 | 02:09 PM
simple's Avatar
it takes a few seconds after coming to a complete stop for the rpms to drop to normal idle speed (i mean drop from 2100rpm or so not the normal 1200rpm it use to be)
i have noticed that when slowing down, if i keep it in gear and let the motor slow its self down too like 1100rpms or so that it wont do what i've been describing in the previous posts, it acts normally
or if it starts to do the high idle deal that i can put it in gear and it will pull the revs back down once a load is put back on the motor...
thanks
Old Jun 29, 2004 | 02:26 PM
ASIM's Avatar
I had a very simluar problem. I changed the fuel filter and cleaned the throtle body and IAC. All good now.
Asim
Old Jun 30, 2004 | 02:37 AM
simple's Avatar
what are you guys using to clean out everything involved with the throttlebody?
Old Jun 30, 2004 | 08:11 AM
IslandZ's Avatar
Throttle body cleaner or good ole carb cleaner, just make sure you don't get it too much on the electrical parts. Oh and don't get it in your left eye, ask me how I know
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
