Idle around 1800rpms!
Old Dec 7, 2003 | 08:47 PM
CMANZ28's Avatar
I just got my car back together. I had the heads gone through and a spark plug hole fixed. But now that I have it back together the idle is around 1500-2000rpms I've checked all the vacuum lines that I could think of. And nothing has changed.
Could I be on the wrong train of thought??? Maybe it isn't even vacuum related... Is there a way to adjust the thottle? I don't think there is but I'll ask anyways. Any input will help.
Thanks in advance,
Chad
P.S. LET IT SNOW
Old Dec 7, 2003 | 11:03 PM
96z's Avatar
96z
A broken TPS can do this, Its been so long but I think there is an idle adjustment screw on the stock TB.
Old Dec 7, 2003 | 11:09 PM
NOMAD's Avatar
If the spark plug hole wasn't fixed properly, you could be getting a vaccum leak there.
-Shannon
Old Dec 8, 2003 | 11:56 AM
CMANZ28's Avatar
Thanks for the advice. But I dont think there is any bad sensors since before i tore the motor apart it was idling at like 800rpms. As for the plug hole, I blelieve everything is good there. They all tighten up and none feel even the slightest bit loose. Would there be a problem with changing the set screw? I've heard dont mess with it??
Chad
Old Dec 8, 2003 | 12:22 PM
Red_94Formula's Avatar
there is an idle screw on the throttle body. the bracket that holds the cruise and throttle control are in the way of it. you can adjust it that way. the idle is also control by the computer which needs to be programed to adjust
Old Dec 8, 2003 | 04:15 PM
CMANZ28's Avatar
I just came in from working on my car. I set the idle screw back and that made no difference since the butterfly's on the Tb are completely closed the "tab" wont go back to the set screw. My car has a 1993 LT1 in it. So I cant reprogram the computer without buying a new chip...right? When I got the car it had a custom chip in it for the mods it had. I'm stumped...can you help!?!?
Chad
Old Dec 8, 2003 | 09:06 PM
CMANZ28's Avatar
TTT
Can anyone help?
Old Dec 11, 2003 | 05:27 PM
CMANZ28's Avatar
TTT
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
