Idle adjustment
Old Nov 5, 2005 | 02:00 PM
'94 Red Dragon's Avatar
Idle adjustment
After my car warms up my idle drops down to about 700rpms. I want to adjust it to 1000rpms. Please help!
Old Nov 5, 2005 | 02:41 PM
slverbullet's Avatar
Re: Idle adjustment
why is this a problem?
is your car auto or manual?
Old Nov 5, 2005 | 02:51 PM
sssalah's Avatar
Re: Idle adjustment
Idle adjustment would have to be done by reprograming the pcm.
Old Nov 5, 2005 | 04:31 PM
Re: Idle adjustment
I have auto. I also have a laptop and a the cable to hook it up, I run datamaster
Old Nov 5, 2005 | 05:06 PM
Re: Idle adjustment
You can't reprogram anything with Datamaster. You need programming software like LT1_edit or Tunercat.
Old Nov 5, 2005 | 06:33 PM
Re: Idle adjustment
and why, still, do you need to adjust the idle from 700 to 1k rpm? just curious?
i was under the impression that ~700rpm idle is normal for an auto.
Old Nov 6, 2005 | 10:48 AM
Re: Idle adjustment
Its smooth at 1000 not 700 and its takes off better. I know that you cant program with Datamaster. I was sayin the a the pc and cable and it works. I have tunercat but it expired. Does anyone know the code to get it for free
Old Nov 6, 2005 | 11:10 AM
Re: Idle adjustment
i would suggest calling tunercat to have them renew your old code, if thats the case. i wouldnt suggest soliciting for someone elses code or a hack code. (not sure if thats what you meant, but thats what i got out of it. might want to clarify).
Old Nov 6, 2005 | 12:42 PM
Re: Idle adjustment
Soliciting software piracy will get you banned from this site. If you want Tunercat, buy it. It's not that expensive.
If your idle is not smooth at 700, you likely have some other problem.
Old Nov 6, 2005 | 12:52 PM
OBE1 95Z28's Avatar
Re: Idle adjustment
Check your knock counts, you may be getting knock when you accelerate from a stop causing you hesitation. If so, you need to determine the source of the knock (tune-up, arcing wires, false knock).
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
