idle
Old Nov 13, 2005 | 08:25 AM
TRIPOWER's Avatar
idle
what should my idle be in park and in gear for my 95? mod are in my sig.
Old Nov 13, 2005 | 09:01 AM
chrism400's Avatar
Re: idle
Idle should be whatever Madz set it at in your program.
Old Nov 13, 2005 | 10:04 AM
TRIPOWER's Avatar
Re: idle
thats what i was thinking. just wondering what everyones is at.
Old Nov 13, 2005 | 12:17 PM
2000LS1Z28's Avatar
Re: idle
Frank,
Factory idle speed for an A4 is set at 650 in P and at 550 while in gear (this at a fully warm idle of course). And before you bought the car off of me, I had Speed Inc check the idle with a scanmaster and it basically showed this to be just about right on. BTW, ignore the tach as it reads a little high both ways...
Also, why did you add a 52mm TB to it? Planning some motor work then? And what did it run at Union Grove the other weekend?
Later,
Mike
Old Nov 13, 2005 | 12:20 PM
2000LS1Z28's Avatar
Re: idle
Ion (MadZ28) didn't change the idle with the tune. He just adjusted the A/F ratio, etc. (part of the performance tune). This used to be my old car FYI...
Old Nov 14, 2005 | 08:45 AM
chrism400's Avatar
Re: idle
Again, Idle is set by the programmer. It is determined by the program.
Old Nov 14, 2005 | 01:46 PM
2000LS1Z28's Avatar
Re: idle
Well, then his program must have been the same as what the original stock programming had the car idling at. All I'm saying is (via an LT1 scanmaster), the idle didn't change in P or gear after his PCM tune was loaded into my car's PCM...
Old Nov 14, 2005 | 09:52 PM
chrism400's Avatar
Re: idle
Right on, Madz can set it to whatever you want. Mine is set at 725 to lope a bit .
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
