idle
Re: idle
Originally Posted by TRIPOWER
what should my idle be in park and in gear for my 95? mod are in my sig.
Factory idle speed for an A4 is set at 650 in P and at 550 while in gear (this at a fully warm idle of course). And before you bought the car off of me, I had Speed Inc check the idle with a scanmaster and it basically showed this to be just about right on. BTW, ignore the tach as it reads a little high both ways...
Also, why did you add a 52mm TB to it? Planning some motor work then? And what did it run at Union Grove the other weekend?
Later,
Mike
Re: idle
Originally Posted by chrism400
Idle should be whatever Madz set it at in your program.
Re: idle
Again, Idle is set by the programmer. It is determined by the program.
All I'm saying is (via an LT1 scanmaster), the idle didn't change in P or gear after his PCM tune was loaded into my car's PCM...
autoxr166
Sep 25, 2015 04:21 PM
