Idle???
Idle???
I was just curious what my cars should be idleing at? I have a 95z with the 2050 compucam, 1.6rr, and some more little things here and there. Its at 900rpm right now was wondering if that was a little high? I had my pcm flashed, was just wondering if they might of looked over that?
Heres the specs on the cam if it makes a difference http://www.cranecams.com/?show=brows...tType=camshaft
Re: Idle???
is it a m6 or a4? m6 idles at around 8-900. a4 idles at 5-600.
some people idle a m6 to 6-700 for a lopier idle. so yours could be fine. unless its a a4. then you should check it out. i personally wouldnt want any lt1 idleing at 500 due to almost nonexistant oil pressure just my .02
autoxr166
Sep 25, 2015 04:21 PM
