iddiot light
Old Feb 19, 2004 | 12:52 AM
spoetzel's Avatar
iddiot light
my low coolent light is on, its a red light with an arrow pointing down toward some water. my engine is heating up to and somtimes over 210 at stoplights. i flushed my radiator and refilled it and also replaced the thermostat with a 180 hypertech thermostat. and the light is still on anyone have any ideas? it a 97,6speed, z28
Old Feb 19, 2004 | 01:31 AM
Z-Scrilla's Avatar
Unplug the sensor.
Old Feb 19, 2004 | 02:56 AM
browneye97ss's Avatar
Ya, Z-scrilla is probably right on this one. I believe that this is a common problem with most of our cars. The sensor will just go bad and start saying there is a colant problem when there really isn't. You can either replace or just unplug the sensor. They seem to be rather touchy with their readings. Might even be able to clean it???? Hope this helps.
Old Feb 19, 2004 | 06:52 AM
zoso1959's Avatar
Re: iddiot light
silly question, but did you bleed your system a couple times after you flushed her?
zoso
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
