ICM not getting power from pcm
Old Jan 13, 2010 | 10:26 PM
HerbzHancock427's Avatar
Im trying to figure out why my car keeps randomly dying.
It will start up run fun for 5 mins or over an hour but randomly dies. I have new coil, opti, wires, plugs(all done within the last week).
Basically ,in testing the Icm harness I have 12v at the pink wire, and ground at the black wire however I dont have power to the white wire with KOEO. any ideas?
PS the car would not start at the time i did these tests, wouldnt make much sense to do them while shes working.
Old Jan 13, 2010 | 10:34 PM
nevermind I was testing the white instead of green. The white should give the pulse correct?
Old Jan 13, 2010 | 11:06 PM
and I am not getting any codes
Old Jan 13, 2010 | 11:32 PM
Maverick_997's Avatar
The white wire on the ICM connector should show between 1-4 VAC while cranking. I think it is the green and black wire(A and D terminals) that should show around 10 VDC with KOEO
Old Jan 13, 2010 | 11:37 PM
ok ive got the two wires at 12 volts KOEO. I have ground on the black wire but no pulse on the white wire. The opti and cap and rotor are about a week old but they are from autozone. I know everyone says they suck but realistically does this sound like i need to swap it with a delco or should i look elsewhere?
ps the problem started 2 days ago when i put in a new coil. I have since put in my old coil but it had no effect on the problem
Old Jan 14, 2010 | 07:04 PM
https://www.camaroz28.com/forums/sho...d.php?t=601565
read through this, it will tell you how to diagnosis the rest.
If you are not getting a pulse from the white wire that means somewhere between the opti-pcm or pcm-the white wire, you could have a short or a loose connection.
DirtyDaveW
Dec 1, 2016 05:37 PM
titanthomas
Apr 18, 2015 11:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
XtremeLt1
Sep 13, 2002 08:50 PM
