ICM and Coil...
Old May 10, 2005 | 06:47 PM
Hawk350's Avatar
ICM and Coil...
Where are these located? I know where the coil is its on the driver's side block right? but where is the ICM located?
Old May 10, 2005 | 07:07 PM
Dave89IROC's Avatar
Re: ICM and Coil...
right next to the coil
Old May 10, 2005 | 11:48 PM
Hawk350's Avatar
Re: ICM and Coil...
If any of these two are bad, or malfunctioning, can this cause detonation problems on cylnders? For instance, some cylinders not firing correctly?
Old May 11, 2005 | 06:23 AM
BLinindoll's Avatar
Re: ICM and Coil...
it would be random missfiring. If it is the same cylinders every time, its prolly either a wire, plug, or the opti.
Old May 11, 2005 | 08:10 AM
94zgreenmachine's Avatar
Re: ICM and Coil...
The coil is bolted to it. There will also be a stud on the head that has a bunch of grounding wires, that stud is also holding it on to the head.
Tons of deposits in the head and/or pistons can cause detonation or possibly a malfunctioning knock sensor, try a little sea foam to clean out the engine. Does it throw any codes?
Old May 11, 2005 | 09:09 AM
Hawk350's Avatar
Re: ICM and Coil...
no codes, justt feels like 1 or 2 cylinders drop for a split second.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
tdigger9899
Sep 7, 2015 10:56 AM
