I want to run 11's
Old May 31, 2005 | 10:19 PM
MonteCarlo84's Avatar
I want to run 11's
I have a 94 camaro Z28, i want to run 11's on the street what do i do. i would like to use the stock ends and stock bottom end Can any body help let me know
Old May 31, 2005 | 11:40 PM
JeremyKweens's Avatar
Re: I want to run 11's
A4 or M6?? Anyways, usually the first step to go fast is do exhaust (long tubes, catback, and remove the cat (s) if laws permit). Slap on a cold air induction, such as K&N. That should get the car close to 300 rwhp....depending on a4 or m6. From there, you have many options really........you can go forced induction (blower, turbo) or do heads and cam (such as the Le2 combo which gives approx 420 rwhp with the supporting mods). Keep in mind with blowers and turbos you will probably need to build up the bottom end of your motor.......so probably not the best option for you.
The easiest way, perhaps, is to put on a decent wet nitrous kit and jet it for 150 hp. Or, you can do a combo of heads and cam, and juice.
And, to top things up, you will most definitely want sticky tires to boot around on the street with. My suggestion is Nitto 555Rs, but others favour BFG drag radials
To put things in perspective for you, I ran a 12.4 with short tube headers, 3" exhaust, cold air, sticky tires, and nx 100 shot of juice.
I have since added a new clutch, PCM tune, and long tubes headers. I dont see why I wont be high 11s this summer.
I hope this helps
Old Jun 1, 2005 | 12:45 AM
Silvershark's Avatar
If you want a good guide, clink on the link in my signature. I have a 1994 M6.
Old Jun 1, 2005 | 10:24 AM
hey thanks, i think i am gonna order some headers in the next week or so
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
