i want a lopey idle
Old Sep 21, 2003 | 02:55 AM
ravigogna's Avatar
i want a lopey idle
i have a 93z with a 6speed
I am going to be buying a cam springs and 1.6 Roller Rockers.
All i have done is hooker long tubes with true duals.
I want a lopey idle but good streetability. What cam would you guys recomend.
Old Sep 21, 2003 | 03:31 AM
ChevyIron's Avatar
I would suggest the CC305 cam a little more aggresive then the hot cam,will give you lopey sound.
Old Sep 21, 2003 | 04:01 AM
jkipp84's Avatar
224/230 is pretty streetable/nice lope/great power.
Old Sep 21, 2003 | 07:37 AM
funina91ss's Avatar
I dont have any complants with the 224/230 here is what my car sounds like with longtubes&borla "wide open plate"video
:EDIT: Madz28.com will burn you a chip for it too.
Old Sep 21, 2003 | 11:34 AM
Rival's Avatar
having a lower lsa(112 and down) will make your idle lope hard. The actual cam you get you may want to look into more. The cc305 and xe224/230 and two milder cams but they should net you a 40hp gain with tuning. They would both be good choices if you don't plan on heads. Look into peoples signtures and check out their dyno numbers and et.'s you'll figure out what you want pretty quick. Good luck
Old Sep 21, 2003 | 12:01 PM
FastZinTennessee's Avatar
HOTcam will lope really nicely. I got nothing but compliments on the sound. Plus if you don't want people to hear it, you can turn the idle up some more and that pretty much covers it up.
John
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
