I want a bulletproof monster! - Please Help
Old Dec 31, 2003 | 01:52 AM
  #16
aram's Avatar
easiest way to pass CA emissions and make 400 rwhp is probably with an LS1.. sorry to say. You can get a complete setup with wiring and accessories for around 2K, add a new k-member.. add some heads/cam and you have 400rwhp and can pass smog no problem.. probably around 5K-6K total. You could probably make 500-700 selling your old lt1 setup too. You also will probably have fewer headaches as you would be dealing with a stock shortblock.. just my 2 cents. If I didn't have a free 355 motor waiting to be put in my car I would have just dropped and LS1 in it and had a way easier time with emissions.
Old Dec 31, 2003 | 01:55 AM
  #17
aram's Avatar
Originally posted by 91 GTA Ramair2
So you don't think my 406TBI would pass ca's emission's test's???
just not visual. No TBI that I know of came in 91 or later cars (actually maybe some caprices? i dunno).. but you can't swap a truck motor into a car in CA.
Old Dec 31, 2003 | 10:19 AM
  #18
SS MPSTR's Avatar
Not likely.
Old Dec 31, 2003 | 10:23 AM
  #19
SS MPSTR's Avatar
Many folks don't realize this is possible...you'll be seeing many more LS1 powerplants in 93-97 f-bodies in the near future.
Old Dec 31, 2003 | 10:24 AM
  #20
SS MPSTR's Avatar
Originally posted by jasons93z
Most people are making 400+rwhp with just a H/C combo. It shouldnt be hard to achieve with a stroker.
I agree, but not while passing CA emissions.
Old Dec 31, 2003 | 08:07 PM
  #21
91 GTA Ramair2's Avatar
I never said my 406TBI came in my GTA factory Nor Did I Imply that the 350TBI was factory Either......
Old Jan 1, 2004 | 06:41 PM
  #22
terlox's Avatar
Would it be harder for a 383 to pass emissions because of the incereased displacment? More displacement, more fuel, etc? If that were the case then wouldn't a beefed up LS1 require the same amount of fuel to produce similar amounts of power?
I would assume one could make a clean running, efficient big block that would put out the same amount of smog as an unmaintained 350?
Would I be better off just buying a crate engine that's guaranteed to pass smog? I'm looking to spend between $3k-$4k and I have yet to see a smog legal crate engine producing 400hp in that price range. Maybe I'm not looking in the right places...
Old Jan 1, 2004 | 10:20 PM
  #23
QCKZ28's Avatar
thats true, but how many can pass cali emissions?
jesse
Old Jan 1, 2004 | 11:05 PM
  #24
viperkiller's Avatar
some guy had a thread a while back on how to beat a smog test by injecting fresh air into the y-pipe or something like that. made sence to me. i dont remember exactly but you could find it on a search.
i dont know the cali emmisions, but if you can get it tuned good you should be able to get it passed. i would look into the lsa on the cams, i think that would be the biggest factor becouse the low lsa is what gives you the "cammed sound" which is actually the car running bad do to low vacume ect...
so if you tune it to run the correct fuel ratio, or you could get tuner cat and have a tune for inspection, then a tune for power. although i dont see why it cant pass under "normal" conditions, while under heavy throttle the computer could forget emmisioins and run like it should.
i say build you a good 383 and spend the time and/or money to have the tunning perfect. then if it doesnt pass do the compressed air in the pipe, or get a freind that does the testing
RX Speed Works
Oct 1, 2015 10:19 PM
NewsBot
Sep 16, 2015 10:30 AM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
RX Speed Works
Jul 24, 2015 02:25 PM
