I Wanna Get A 383 Stroker???
Old Sep 2, 2004 | 02:14 PM
gabeg94z's Avatar
I Plan On Getting A 383 Stroker With Ported Heads,hotcam,4 Bolt, The Works But What Do I Need, As Of Rear End Tranny, Can I Keep My Rear End And Tranny Or Do I Need To Up Grade, Any Help Is Appreciated
Old Sep 2, 2004 | 02:53 PM
kgkern01's Avatar
Re: I Wanna Get A 383 Stroker???
If you have a A4, u may want an upgrade, definitely a higher stall TC, possibly some A4 guys can chime in on that. An M6 will be fine with an upgraded clutch, although the T56 can be built beefier as well. As far as the rear, a stronger rear is definitely needed with a 383.
Old Sep 2, 2004 | 02:59 PM
SantaCruz163's Avatar
If you are using ported heads on a 383 I'd suggest a bigger cam than the hotcam, not saying that it wouldn't work.
Old Sep 2, 2004 | 03:04 PM
kgkern01's Avatar
I agree.
Old Sep 2, 2004 | 03:08 PM
97SS0594's Avatar
i agree on the bigger cam, a hot cam will choke a 383.
Old Sep 2, 2004 | 04:34 PM
gabeg94z's Avatar
ok to tell you the truth i dont know what kind of tranny or gears i have on my car, also it is a 94 z28 6 speed
Old Sep 2, 2004 | 04:35 PM
gabeg94z's Avatar
also what would be a better cam.
Old Sep 2, 2004 | 05:06 PM
bdc95ta's Avatar
you can get your heads ported by loyd and get his le1 cam. The le1 is very similar to the hotcam but makes more power and tq everywhere.
-b
Old Sep 2, 2004 | 05:25 PM
gabeg94z's Avatar
who on here can make me a 383 a good working one and how much just to compare prices
Old Sep 2, 2004 | 05:45 PM
TQdrivenws6's Avatar
Why go as small as the LE1 on a 383? I am doing the LE2 kit on mine, and it will probably peak 6200-6300rpm. As far as price, that really depends on how nuts you want to go. You can go cheap with a cast crank, stock rods, and hyper pistons, but I wouldn't spin it very high like that. And as far as going the other way (more $$$) the sky isn't the limit, its much higher than that.
Old Sep 2, 2004 | 05:59 PM
gabeg94z's Avatar
i was price 3600 for mine is that to much or cheap
Old Sep 2, 2004 | 06:01 PM
That really depends, if that is just the rotating assembly, that will be very stout! But if that is the complete engine, that seems low, unless its running on stock heads/cam which is a sin on a 383.
Old Sep 2, 2004 | 06:05 PM
gabeg94z's Avatar
thats intire engine with ported heads and my cam choice
Old Sep 2, 2004 | 06:59 PM
Formula03's Avatar
It is possible to build a good 383 for $3500-$4000. Mine was a little under four and was built right(however if you plan on using a hefty amount of n20 then it will cost you a bit more).
Old Sep 2, 2004 | 07:02 PM
gabeg94z's Avatar
Im Not Really Into N2o Or Sc Or Turbo I Like Nothing But Motor I Might Get Owned Everyonce In A While But Ill Give Some Comp
