I think I'm screwed! Water pump threads on block rusted!
Old Nov 10, 2003 | 10:30 PM
Rob94hawk's Avatar
Exclamation I think I'm screwed! Water pump threads on block rusted!
The threads in the block have rusted and it's really hard to get the water pump bolts in there. Any suggestions? Thanx, Rob
Old Nov 10, 2003 | 10:36 PM
Kain's Avatar
First try some carb cleaner and a small wire brush for cleaning dishes, something that won't mess up the threads and disolve the rust.
That or get a tap and dye (sp?) set and clean up the threads.
Old Nov 10, 2003 | 11:38 PM
Compstall's Avatar
It's not that uncommon. If the bolts are that bad just replace them.
Old Nov 10, 2003 | 11:43 PM
jasons93z's Avatar
Try some brake cleaner. It will get in there and dry up the rust. Then spray some wd-40 in there to get it out. Thats what i would do.
Old Nov 11, 2003 | 02:52 AM
BBoyce's Avatar
1 word, Kroil. This stuff is great.
Ben
Old Nov 11, 2003 | 08:25 AM
RTZ-28's Avatar
wd-40 doesnt do anything for me and rust, i use pb-blaster that stuff works great with actually breaking down rust ive used it on every car ive had when replacing things
Old Nov 11, 2003 | 10:36 AM
leadfoot94's Avatar
I second PB Blaster, it's second to none.
Old Nov 11, 2003 | 10:40 AM
Terran2k's Avatar
i used pb blaster on the bolts holding my coil in, worked good for me.
Old Nov 11, 2003 | 11:18 AM
Josh-'04 GTO's Avatar
Gotta get a new block........just kidding! As mentioned, hit it with some PB Blaster or WD40. If it still seems messed up, clean up the threads with a tap.
Old Nov 11, 2003 | 12:05 PM
Rob94hawk's Avatar
I let some wd40 sit on the threads overnight, in the block and on the bolt threads. I'll try to get them in soon. If this doesn't work I'll try PBblaster. If that doesn't work, I'll just have to tap them.
Thanx
Old Nov 11, 2003 | 04:35 PM
RTZ-28's Avatar
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Sandersen511
Jan 13, 2015 03:49 PM
