I take it pushrods aren't supposed to spin freely
Old Sep 6, 2006 | 12:08 AM
Finchinater's Avatar
I was struggling changing my plugs and wires tonight and thought while I was there I would replace my valve cover gaskets. I was wiping off one of the rockers when I noticed it wiggled. I take it that it's not supposed to do that.
I'm guessing that I need to re-adjust the valve lash, correct. I pulled up shoebox's site and the easiest method for me would be #1. I don't understand what "pre-load" is. Is it the 1/4 turn after you have taken the slack out of the pushrod?
Going to bed. I'll get back at it tommorrow night.
I appreciate any comments.
Finch
Old Sep 6, 2006 | 12:47 AM
97bowtie's Avatar
Re: I take it pushrods aren't supposed to spin freely
It's normal for the rockers to move from side to side a little. As long as there is no vertical play in the rocker/pushrod, and you don't hear any abnormal ticking from the motor, I wouldn't worry about it.
Old Sep 6, 2006 | 11:08 AM
1racerdude's Avatar
Unless they are clicking/clacking,don't worry about them.
Old Sep 6, 2006 | 11:25 AM
Sweetred95ta's Avatar
If you do adjust them anyways, yes, the 1/4 turn is the preload.
Old Sep 6, 2006 | 11:35 AM
Heatmaker's Avatar
Advanced Member
That's what thier supposed to do. Either the valve was closed, or open half way. It's not a problem unless you can lift the entire rocker and move it freely.
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
