i swaped rearends, now clucking noise from the back!!
Old May 15, 2003 | 01:11 PM
tealdevil's Avatar
Unhappy i swaped rearends, now clucking noise from the back!!
i just put a 93 rearend on my 94z A4, and now everytime while i'm driving a loud clucking noise comes from the back, does anyone know whats up with that, its driving me crazy, i did install eibach pro springs, and i asked they guy at the shop if its possible the springs are lose he said no, do i need to change anything to complete the swap, i'm i missing something, or they exaxtly the same rearend..
thank you..
Old May 15, 2003 | 01:14 PM
qwick_trip's Avatar
did you switch the driveshaft or is that the same?
Old May 15, 2003 | 01:44 PM
1997rblckSS's Avatar
when does it clunk, does it only do it when you put a load on it, does it do it when you are just cruising at a steady speed?
Old May 15, 2003 | 08:47 PM
tealdevil's Avatar
no i still have the same drive shaft, and it does it while i'm just cruising, coming to stops, hitting bumps the most, and putting it from D to R and R to D..
need help please, i'm going crazy..
Old May 16, 2003 | 08:17 AM
Ryan94Camaro's Avatar
Your control arms bolts and or panhard rod bolts are loose. Mine did the same thing.
Old May 16, 2003 | 12:21 PM
tealdevil's Avatar
ok, checked control arms and panhard, they have a little play but not much, and i also checked springs, all am wondering is would the 93 rearend fit a 94, or was it a big mistake from the begining??
Old May 16, 2003 | 01:24 PM
Naah, after I broke my rear in the 96, I put a 93 TA rear end under my car. You really gotta crank down on the bolts.
Old Sep 6, 2003 | 02:48 PM
tealdevil's Avatar
so 93 rearend would fit, its just need to be really tight.. is that right????
thanx...
Fatdog2
Feb 12, 2015 12:24 PM
ddr698
Jan 31, 2015 10:58 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
squarehead
Nov 21, 2014 08:02 PM
