I REALLY f'ed up, experts please help...
Old Dec 19, 2003 | 03:53 AM
  #16
96 WS6's Avatar
Thanks... they sell those fuel injection hose clamps, the exact same ones at kragen. I don't really want to do that though. I will hate myself every time I drive if that ghetto band aid is on my fuel line. I'm just going to replace the sender assembly.
Old Dec 19, 2003 | 04:21 AM
  #17
jasons93z's Avatar
I dont think they are trying to be mean to you, you could have really blown yourself up. Sparks+gas= But yes, it looks like youll need a new gas line. Be careful
Old Dec 19, 2003 | 02:36 PM
  #18
bunker's Avatar
Hey no probs I might have what you're looking for, it comes complete with no pump, you'll just have to transfer your fuel pump over, PM me & make me an offer Its the whole unit minus the fuel pump.
Matt..
Old Dec 20, 2003 | 07:20 PM
  #19
Gary 95 Z28 M6's Avatar
Fuel lines along with brake lines can easily be repaired with a double flaring kit and some new fittings. If you know what you're doing you can fix that in 20 min. If I were you, I would definetly go that route vs. putting a whole new line in.
Old Dec 20, 2003 | 09:47 PM
  #20
Heatmaker's Avatar
Advanced Member
why not just use a flare kit...? If it's good enough for something as serious as your brakes it's good enough for your fuel lines.
Old Dec 20, 2003 | 10:04 PM
  #21
scoobysnax83's Avatar
Yea, seriously. Brake Fluid is just as potent as gasoline. Its not going to eat through it or anything and its a much more reasonable fix then replacing the entire fuel line. No way in hell, would I even think about replacing the whole thing for such as small cut.
Good Luck...
Old Dec 20, 2003 | 10:23 PM
  #22
ChrisUlrich's Avatar
Yo
Compression Unions are mostly used in plumbing... go to a plumbing store. Its sized different though as its measure outside diameter and not inside. i.e. 1/2 = 5/8 and 3/4 = 7/8
Old Dec 21, 2003 | 12:57 AM
  #23
aram's Avatar
Just flare it, pep boys loans flaring tools, shouldn't take very long. If you are really worried find someone parting a car and replace the whole assembly. I sold one on ebay for about 50 bucks a while ago. Rubber hose would probably be fine too.. just replace it every couple of years or something and use the rubber fuel injection hose not the stuff for carbs.
You cut a giant hole in your unibody and are worried about repairing a fuel line being a hack job?
Old Dec 21, 2003 | 01:32 AM
  #24
S.J.S.'s Avatar
Sorry to go off subject, but I saw this before and had to ask. Is this the usual way everyone is changing their fuel pumps??? I guess its way easier than dropping the tank huh.
Old Dec 21, 2003 | 02:13 AM
  #25
96 WS6's Avatar
What is a flare kit? I've never heard or seen it. How does it work? The line is not a line that goes all the way to the front, it's just one coming off the sending unit. So I don't know, how would I go about fixing if with a flare kit?
Does anybody have a good sending unit for sale? Are all years interchangeable?
Old Dec 21, 2003 | 08:32 AM
  #26
Hawk's Avatar
It's the latest rage...................
But do it at your own risk
Old Dec 21, 2003 | 09:10 AM
  #27
hawk232's Avatar
guys, he doesnt even know what a flare kit is, i think he would be better just replacing the whole thing, because if you dont know what you are doing and watch it you can make and uneven flare and it will leak.
Old Dec 21, 2003 | 09:37 AM
  #28
Hawk's Avatar
well, if you never did the flare kit thing like stated earlier, maybe you have a friend that can help you?? Or, you have a mechanic that can do it for you cheap?? Just some other thoughts.
Old Dec 21, 2003 | 12:02 PM
  #29
revtime's Avatar
cutting an access hatch saved my butt since I had to go back into the tank to fix some fuel problems.
If I had to drop my rear to get to the tank 3 times I would have killed somebody.
I plan on keeping my car till I die, its just too much fun but if you do plan on selling it someday then you might want to put in the extra effort and do it the right way.
Just for the record I have not seen one problem with my access hatch and it is SOOOO much easier to work on the pump.
Old Dec 21, 2003 | 01:15 PM
  #30
Heatmaker's Avatar
Advanced Member
This is a Flare Kit
Kit
You can rent them at Auto zone...all you need are the Line Fittings. Once you get the measurements of your fuel line you can probably get those fittings for them at nappa.
I wouldn't knock the idea of flaring either...It's been a quick fix it trick for years. Even if your not sure about using the kit just take it to a shop that can for you. It's cheaper and easier to do than replaceing the entire line. Don't giv
