I raced my buddies 00 SS. Results inside.
We raced twice. the first time we started at about 10mph up to 100 and i beat him by 1 car. The 2nd time we started the same, except i closed off the cut-out and i beat him badly.
Any reason?????? His SS is an m6, ram-air of coarse, and borla cat back. Overall i was VERY pleased with the results. Im thinking when i go to the track i should be pretty good in the 12's.
THis was on a closed road btw, i dont condone street racing
Re: I raced my buddies 00 SS. Results inside.
Good run on your part. He probably should be able to beat you or start catching you in the latter half of the 1/4, but it sounds like you have a strong LT1 and him having a weak LS1. What's your best time in the 1/4 and or dyno numbers?
Jason
Jason
well, i ran a 13.5 before the headers and the 1.6rr's. So im probably close if not in the 12's. He has run his SS at the track and it ran a 13.1. He is a pretty good driver.
Jason
Jason
. The guy has almost a full bolt on LT-1, im not at all suprised that he smoked that LS-1. I know how strong LS-1s are but come on his friends car just has a cat-back on it. Start giving LT-1s more credit.
Originally Posted by lt1maro
That is total BS
maybe its just my luck..but my bolt on lt1 never has had a problem with a stock ls1..maybe its my gearing? or maybe its because the powerbands fo the two engines are different..i know ls1s are peakier..but i would definately say a full bolt on lt1 puts out more power then a stock ls1
Originally Posted by stik6shift93
Hate to break it to you but thats not the case, bone stock ls1s put down just as much if not more more than 90 percent of the full bolt on lt1s. They also are about a 100lbs lighter to which equates to a .1 faster equivalent power for power.
I think you misunderstood. I was just referring to Speed_demo24's response to stik6shift93's post
I believe ya
And yes weight plays a big part in what options are for each car.
I believe ya
That is total BS
. The guy has almost a full bolt on LT-1, im not at all suprised that he smoked that LS-1. I know how strong LS-1s are but come on his friends car just has a cat-back on it. Start giving LT-1s more credit.Jason
