I need a straight answer
Old Jul 25, 2004 | 06:13 PM
RedHottG2's Avatar
With the LT4 KM and sensor, do you need both or just one or the other for a OBD1 car ? I'm really confussed about this so I thought I would get the right answer from someone. Just to clear things up, KM goes in the PCM and the sensor screws into the block correct.
Old Jul 25, 2004 | 06:36 PM
RedHottG2's Avatar
Re: I need a straight answer
I'm assuming all I need is the KM for the PCM, is this correct ?
Old Jul 25, 2004 | 07:12 PM
Camaro_Maniac63's Avatar
Yes, just the knock module.
Old Jul 25, 2004 | 07:16 PM
Kataklysm's Avatar
You don't need the sensor that goes into the block, just the one that plugs into the PCM.
Old Jul 25, 2004 | 07:48 PM
ibanez6rg's Avatar
Yulp, the sensors are the same in the LT1's and LT4's. Just different modules.
Old Jul 25, 2004 | 08:13 PM
To clarify that a little-all 1996-1997 knock sensors are the same (LT4 or LT1), but they are not the same as the 1993-1995 knock sensors and are not interchangeable. The knock modules are interchangeable 1994-1997 (1993 does not have a removable module).
HibachiZ28
Nov 6, 2015 12:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
colts0455
Sep 2, 2015 12:41 PM
Catmaigne
Jul 14, 2015 05:17 PM
Boss002
Jul 9, 2015 03:33 PM
