I need some help please...
Old Jan 8, 2006 | 07:11 PM
Sinister95Z's Avatar
I have run into an issue with starting my car. It is becoming a serious issue because I am moving here in the next week or so. My car will not start. I can not get the car to turn over AT ALL. I just put on a brand new battery and a brand new LT4 starter. What could cause my car to not even crank? It is a 95 Z28 6 speed. I am stumped. Please help me out. Thanks guys.
Old Jan 8, 2006 | 07:13 PM
MEAN LT1's Avatar
Re: I need some help please...
Well, are you getting spark?, fuel?, do you see the security light flash in acc position?.
Old Jan 8, 2006 | 07:15 PM
My fuel pressure is fine and I can't tell if I am getting spark because the car will not turn over at all.
Old Jan 8, 2006 | 07:20 PM
valter's Avatar
Check all connections, ignition switch, VATS, fuses. I think VATS.
Edit: that LT4 starter ever worked?
Old Jan 8, 2006 | 07:25 PM
Yes...I had it tested after installing it thinking that might have been a problem. And I didn't think 95's had the VATS??
Old Jan 8, 2006 | 07:27 PM
Also, I checked all the fuses without any luck.
Old Jan 8, 2006 | 07:38 PM
valter's Avatar
On http://shbox.com/1/vats_bypass.jpg there a VATS for 93-95 and BCM for 96-97.
Old Jan 8, 2006 | 07:53 PM
chuckd4more's Avatar
Could easily be that switch that says your clutch is depressed.
Old Jan 8, 2006 | 07:56 PM
bowtiethunder's Avatar
possibly ignition switch
Old Jan 8, 2006 | 07:58 PM
That is what I am starting to think....if they are not that expensive I will pick up a clutch switch tomarrow. Any way of testing it to see if that is the problem?
Old Jan 8, 2006 | 08:00 PM
1 Nasty Bird's Avatar
Ok wait, is the starter making noise when you try to start it, or n o noise? A click from the solenoid, does it sound like the starter is grabing the flywheel and just cant turn it? Have you tried cranking it with a breaker bar off the balancer bolt? Have you tried push starting it since its a 6 speed?
Im not sure if your starter isnt engaging or if your motor is just locked?
Old Jan 8, 2006 | 08:25 PM
The starter is not making any noise at all. You can definetly not hear the starter contacting the flywheel. When I try to start it, there is no noise whatsoever.
Old Jan 8, 2006 | 08:34 PM
Worst case scenario if you have to move the car and you didnt figure it out yet have someone push start it and drop it in second should start right up.
the security lights not coming on when you try to crank it? Make sure the bulb works watch it when you first turn the key should light up for a few seconds then die out. If your not getting a security light id suspect the ignition switch. But id first get under the car and try to manually bump the starter, while making damn sure its out of gear and someone is around to make sure nothing crazy happens.
Old Jan 8, 2006 | 09:15 PM
Found it. It was the clutch switch. My Mom's boyfriend had a spare one in his tool box. Switched them out and the car started right up. Thanks guys.
Old Jan 8, 2006 | 09:17 PM
6SpdLT1Z's Avatar
Good to hear.
