I need plugs for A.I.R. fittings in headers
Old Jun 25, 2003 | 09:14 PM
Dave Feerst's Avatar
where can I get them?
Old Jun 25, 2003 | 09:21 PM
5thCamaro's Avatar
I just went to the local speed shop and they had what I needed. Just remember that is what they do every day so they always have ideas and solutions.
Old Jun 25, 2003 | 09:36 PM
Im in BFE Indiana now, The nearest one I know of is 30 mins away and its not that good. but I guess Ill give them a call in the morning.... anyone know a place i can order them if they dont have them?
Old Jun 25, 2003 | 09:48 PM
nateh's Avatar
I live in BFE Indiana. Find the nearest Jiffy Lube or equivalent and ask for an M22X1.5 plug. It just so happens to be the same size as a Toyota truck differential plug. Even BFE, Indiana has a Jiffy Lube.
Old Jun 25, 2003 | 10:18 PM
thanks!
Old Jun 25, 2003 | 11:04 PM
joefreeland's Avatar
SLP told me that the threads for the air tubes were 7/8-18. I ordered some plugs that size, should be here this week. I will post if they work.
Brad
Old Jun 25, 2003 | 11:27 PM
CamaroRob97's Avatar
anybody have a link to removing the whole LT1 smog system??? This is something that i've wanted to read up on for a while but have had no real step by step instrucions
Thanks!
Old Jun 25, 2003 | 11:34 PM
SlowAssTA's Avatar
i bought some brass plumbing caps from Home depot, the 5/8's fittings screw on just fine...
Old Jun 26, 2003 | 05:17 AM
anaik's Avatar
Re: I need plugs for A.I.R. fittings in headers
What year car do you have? They're not all the same. Put what you're driving in the sig, that's what it's for. Makes it easier to answer your questions.
The 94-95 use a 7/8 x 18 or 22 mm will work. The 96-97 use 3/4 x 16 or 18 mm.
If you can't find them locally, here's a site with all kinds of drain plugs. Get copper washers too, or use some high temp sealant under the head.
www.cgenterprises.com
Old Jun 26, 2003 | 10:56 AM
JoshGuitar's Avatar
here's what I did...slightly "ghetto" but works fine.
Take a hacksaw to your original AIR system piping and cut the flare off of the end of each pipe so you can slip the nut off of it. This nut obviously is the right size for the AIR bung, only problem is it isn't much of a plug, on accounta the big hole in the middle . Put a lil sealant on a penny (sealant might not be necessary but why take chances), drop it into the AIR bung (should sit right in there, at least it did with my headers) then screw the original nut down on top of it to hold it in place. Actually I had to stack up 9 pennies, cuz my headers didn't have the right thread, and I could only get the plug in a turn or 2...but if I coulda screwed it in all the way I guess only one penny woulda been necessary.
Old Jun 26, 2003 | 03:30 PM
Robbie Pendergrass's Avatar
I just welded up the center of the stock AIR fitting nuts.
Old Jun 26, 2003 | 06:46 PM
only problem whith those ideas is that I may need to make it emissions leagal again.
The 7/8 18 was too big for my 94, In fact, at the smallest point the 7/8 plug was .840 the hole is .800
Mabye i should try the 3/4... with the taper it should be a better fit.
Old Jun 27, 2003 | 10:52 PM
arnie's Avatar
7/8" X 18 tpi is correct. For those that say it is smaller, I say I prefer not to plug an adapter that is screwed into the manifold. It is NOT metric. Yes, it will screw in, however, the tpi is incorrect. Cuz the OD of the metric plug is sloppy enuf, it will screw in till it wedges. It has worked, but is not correct. Done correctly, the plug will bottom out against shoulder in hole to seal, not wedge in the thread. The hole is an inverted flair thread, not meant to be plugged. Someone once stated they knew of a source. Don't remember. However personally speaking, AFAIK, the plugs that are available, are custom made. I know a source from another forum if necessary, and no, they are not as inexpensive as metric drain plugs.
Old Jun 28, 2003 | 03:18 PM
nateh's Avatar
I suspect that different headers require differing sizes of plugs. I measured both the stock AIR hole and the one on my headers. They were different. The headers' AIR tubes were indeed metric and the plug that fit perfectly was an M22X1.5. If you need something that is the same size as the stock fittings, it will probably be one of the SAE sizes mentioned. I haven't seen any listing of what sizes the stock AIR fittings are on what years, (assuming a change due to OBDII), nor have I seen a listing of the size plugs required for different headers.
I have RKSport/ASM Headers and the AIR tubes take an M22X1.5 plug. Anyone want to volunteer their AIR tube plug size and what headers they fit?
Old Jun 28, 2003 | 04:07 PM
anaik's Avatar
Like I stated above my '95 cast iron manifolds took a 7/8 x18. When I got FLP's, I would have had to switch to 96-97 AIR tubes which are 3/4 x 16, the size of the plugs I'm using now. I think the reason the M22's and M18's can be used in there place is because of corrosion in the threads. I had to run a tap in the fitting of my FLP's, because of the coating in the treads, for the 3/4 x 16 plugs to fit.
