I need my factory exhaust hangers back!
Anyone know where to get the factory exhaust hangers? I got my Magnaflow catback system in, and it will be replacing my Flowmaster catback. The Flowmaster system had the hanger/hooks welded to the system, and they slide right into the insulators on the frame. So, the factory hangers got thrown away I guess. The Magnaflow system has a square piece of steel with a hole drilled in it. No hook! I'm guessing the factory hanger/hook bolts on here to slide into the insulator mounted on the frame.
Anyone have the part #?
Re: I need my factory exhaust hangers back!
Left side 10272958
Right side 10288522
this is just the hooking part between the bracket on the pipe and slides on the rubber insulator....
Check with your dealership to confirm this is the part you need..
Right side 10288522
I had the same problem, the previous owner had installed an Edelbrock cat-back and I changed it to a Magnaflow along with my header install. The factory hangers were long gone so I ended up fabricating my own stuff. It would have been much easier just to buy the stuff from the dealer, but I had some free time and a welder so I got ambitious.
Originally Posted by n2ceptor
Left side 10272958
Right side 10288522
Right side 10288522
Thanks!! Yes, its number 24 and 13 on this diagram that I need.
http://shbox.com/1/exhaust_system.jpg
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
