i need help with oil pump on 95 lt1
Old Jun 14, 2009 | 10:12 PM
cwilson611's Avatar
do you have to pull the engine to replace the oil pump on a 95 lt1
Old Jun 14, 2009 | 10:28 PM
chevyz4life's Avatar
no
just the oil pan. I been told you need to lift the engine a little too be able too pull the pan thou.
Old Jun 15, 2009 | 07:45 AM
bw_hunter's Avatar
It's a pain but can be done in the car. You have to jack the engine way off the mounts.... remove the oil level sensor and dipstick tube and turn the crank to a certain position just to slide the pan out. Once it's off, changing the pump is pretty easy.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Aug 8, 2002 02:53 PM
Captain Kirk
Jul 26, 2002 06:39 PM
