I need help!
Old Nov 1, 2011 | 01:36 PM
mgoering156's Avatar
I need help!
Hey everybody i have a 1994 z28 and everytime I drive it the Low Trac, Brake, and the ABS INOP lights all come on at the same time they blink for about 2 seconds and then they stay on for about 2 seconds then they go away and repeat it all over again. i also noticed my reverse lights are out could that be a factor. also the low coolant light is on but the radiators full and the airbag light blinks sometimes. thanks for reading any help would be greatly appreciated.
Old Nov 1, 2011 | 03:40 PM
Re: I need help!
Sounds like you are having a low voltage issue. It can cause the warning lights to act weird. The low coolant sensor thing is a common.and separate issue.
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
