i need help
Old Aug 28, 2008 | 07:58 PM
jeremy stanke's Avatar
i need help
my car was running fine until it wouldnt start. it will crank over but not ignite, i thought it was the plugs so i changed them. now it starts up but if i shut it off and try to start it again it wont. once i let it set/cool for a couple of minutes it starts back up again. when it is running it runs fine, i was having some trans problems also but now that seems to be ok now also. is it something electrical?
Old Aug 28, 2008 | 08:00 PM
oh yea, its a 95 automatic z28
Old Aug 28, 2008 | 08:46 PM
irishz28's Avatar
is there a check engine light on ?
Old Aug 28, 2008 | 09:04 PM
no check engine light and no codes
Old Aug 28, 2008 | 09:19 PM
Green96Z's Avatar
Check your ICM. I had a problem where my car just died, then I would let the engine cool it would start right back up. The ICM doesn't like heat, but sadly it sits right on the cylinder head.
Old Aug 28, 2008 | 11:11 PM
my car isnt dying though, it runs fine until i shut it off
Old Aug 30, 2008 | 08:33 PM
i just seafoamed the car and it seems to have helped a bit but when i start it up it idles really rough for a minute or 2 and then it sounds like it clears it self out idles up to 1500 rpms and then settles back down to 8-900 and idles smoothly
