I need a dynoproven airfilter that FLOWS
Just dynoed this weekend and gained ~8rwhp by removing the Moroso CAI completely. I'm going to fab up some 4" piping, but I need an air filter. As you can see, I *thought* I had enough filter...
Larger K&N air filter (not the stock Moroso)
Modified Moroso CAI
I have seen some HUGE K&N filters, but I'd really like to hear from anyone who has dynoed before and after with their CAI on/off.
Ryan
Modified Moroso CAI
Ryan
honestly the size of the filter isnt that important. a while back either hotrod or chp did a dyno study with the same engine and different sized kn filters and they were all within abotu the same hp. and one of the smaller filters actually outdid alot of the bigger ones
If you really removed it completely then your gain didn't come from losing the filter, but from losing the crimped tubing that fits between the radiator shroud and the ABS. There isn't much to do about this restriction without removing or relocating the ABS.
-Chris
-Chris
I will be heading to the store/yard for some steel flatbar and some brake lines - time to get a little creative
I can speculate what the loss is from, but I am kicking myself for not pulling the filter only on the dyno to see what would happen.
Its purely speculation right now which is what I wanted to get away from.
Ryan
. I can speculate what the loss is from, but I am kicking myself for not pulling the filter only on the dyno to see what would happen.
Ryan
You know what would be nice, would be a 4" mandrel bent piece of aluminum or thin guage steel, then have it coated on the inside with something quite slick, probably only fit without ABS though. I would think that would flow quite well, just slap a conical K&N on there.
I'll get pics of whatever I end up with
.Ryan
Formula Steve
Sep 19, 2023 08:31 AM
camaro02DK
Jul 5, 2015 09:24 AM
