I know I need the tune, BUT.....
Old Aug 19, 2004 | 09:17 PM
Droff's Avatar
First of all, I am getting the tune. I had to replace the head gaskets so I changed the cam and got a p&p. But since the cam was just the 305 I knew it would run with the stock program. But my G-Tech says I lost about a second and about 25 HP from before the mods.
I thought I sould at LEAST be back to stock with out the tune.
Is the tune going to get me back to stock and THEN the 30-50 HP more that this mod is suppose to give!!??
Or do I have something wrong that others have seen?
Any help or comments appreciated.
Old Aug 19, 2004 | 09:49 PM
Spinner's Avatar
Re: I know I need the tune, BUT.....
Cam's not going to run well until you get some gears. 2.73 + stock converter + cam = slow
Then get it tuned.
Old Aug 19, 2004 | 10:03 PM
DarkHorse's Avatar
But how much, realistically, is an email tune going to be worth? I'm considering it now too. Hopefully I can pick up 1-3 mph, is this expecting too much???
Old Aug 19, 2004 | 10:11 PM
dabez1's Avatar
its definately worth it as far as ive seen. Tune is practicly a must if you want to see the true benifit of a cam
Old Aug 19, 2004 | 10:12 PM
Droff's Avatar
I know I need the gears also. But should I lose HP? I thought the cc305 was not THAT much bigger than stock. I though others with the 305 at least got back to stock before their tune. ???
Old Aug 20, 2004 | 12:25 PM
TransAmGT94's Avatar
You need a tune to make a cam run at it potential no matter the size im sure you will pick up quite a bit of hp with a tune
Old Aug 20, 2004 | 12:44 PM
Will84's Avatar
The cc305 is way better than stock. I can't remember the stock #'s but the cc305 is 220/230 .510/.510. The cc305 makes a pretty noticable difference with stock tune. I had 3.73's and a 2800 stall before installing mine though... so I guess that may be your problem.
Old Aug 20, 2004 | 06:17 PM
Spinner's Avatar
You might be making the horsepower, but the gears you have are putting too much a load on the cam at low RPMS, and its not going to pull nearly as strong under a big load. Get some gears, or a stall, preferably both.
Old Aug 20, 2004 | 07:08 PM
Droff's Avatar
Thanks for eveyones reply. My prob happen to be FLP TL's. It is really hard to put #5 wire on. It came off hit the header and melted a bit. Shorted out #5. Fixed that now I gained 15HP on the stock tune. Should be what I am looking for when I put the tune in.
Thanks!
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
