I have OBDII?!
Old Jul 6, 2004 | 08:15 PM
SantaCruz163's Avatar
I have OBDII?!
I checked my fuse box and see that I have 3 cooling fan relays and apparentely this indicates OBDII. Is this true? I always thought 95s were OBDI. I don't want OBDII
Old Jul 6, 2004 | 08:25 PM
slopokrodrigez's Avatar
No 95's have OBDI but use the OBDII connector.
Old Jul 6, 2004 | 08:28 PM
ThirdGenLT1's Avatar
I'm no expert on the matter, but I would check to see how many 02 sensors you have. If you have 4, it's OBDII, if only 2, it's OBDI.
I don't know about the fan relay thing. My harness is back at school, and I think it may have had a few relays/fuses for the fans and it's OBDI.
Old Jul 6, 2004 | 08:33 PM
ScrmngChckn95's Avatar
You don't have an OBDII. The only OBDII's that came from the factory were on the automatic california emissioned lt1's, and on the optional 3.8L V6, that started in 95.
Old Jul 6, 2004 | 09:23 PM
Fan relays have nothing to do with OBD type. Look on the sticker on the radiator cover. It will tell you what OBD type it is.
Old Jul 6, 2004 | 10:30 PM
BlownF1's Avatar
California emissioned automatic LT1's (that's me!) got dual cats, NOT OBDII...just the OBD-II connector, but an OBD-I PCM. We're special...
Old Jul 7, 2004 | 11:05 AM
Read this post for the manual fan switch GP. http://web.camaross.com/forums/showt...74#post2293374
Originally posted by notstock4long
Just to clear up any confusion, here is basically how the OBDI/OBDII stuff goes. If your car is a '93-94, it will be OBDI. If it is a '96-02, it is OBDII. If it is a '95, it could be either, so you will have to check, if you don't already know. To check, just pop open the fuse/relay box on the driver's side of the engine bay. If there are two Cooling Fan relays, your car is OBDI. If there are three Cooling Fan relays, your car is OBDII.....
What is that all about, what do I need OBDI or II? Does he have no idea what hes talking about?
Old Jul 7, 2004 | 11:42 AM
moparman's Avatar
LIke shoebox said: check the underhood sticker. If your '95 is OBDII, it'll be the first one discovered on this board.
Old Jul 7, 2004 | 03:23 PM
well i checked and it is a OBDI
Old Jul 7, 2004 | 04:20 PM
Mtrhds94Z's Avatar
Above is not correct..
for starters, the fan change from 2 to 3 relay fans was made in mid 94 [referred to as 'early production(2 relays) or 'late production(3 relays) in 94 factory manual..]
95's are OBDI and have OBDII ALDL..
Jeff'SS
Jun 1, 2015 06:21 AM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
aj2494
Mar 12, 2015 10:17 PM
InfernalVortex
Jan 17, 2015 09:35 AM
thermwood1
May 11, 2003 02:46 AM
