I Hate The Stumble!!!
Old Apr 2, 2004 | 09:54 AM
  #16
94NDTA's Avatar
It isn't throwing any codes. Do I need a special scanner for this, or just any ODB I scanner?
Old Apr 2, 2004 | 10:34 AM
  #17
94NDTA's Avatar
I do have a tear in the bottom of my intake elbow, right where it connects to the TB, would this do it?
Old Apr 2, 2004 | 11:51 AM
  #18
SATANAZ666's Avatar
dUDE THAT WILL DEFINITELY DO IT!!!!!!!!!!!!!!!!
Old Apr 2, 2004 | 03:11 PM
  #19
Gripenfelter's Avatar
Yes that will do it.
Because your car is getting un-metered air.
Old Apr 2, 2004 | 07:16 PM
  #20
94NDTA's Avatar
To see if that is it, would it be ok to duct tape it and try it?
Old Apr 2, 2004 | 08:06 PM
  #21
surfinmud's Avatar
duct tape should do the trick. Also, you could unplug your MAF so that the car goes into mass density mode and doesn't use the maf sensor.
If the stumble clears, then you found your problem.
Old Apr 2, 2004 | 09:04 PM
  #22
94NDTA's Avatar
Un plugged o2's, didn't fix it, duct taped and unplug the MAF and it din't fix it. If it were a vacume leak, wouldn't I be able to hear it? What are some other small things to check. At ther high school; here, they just got a brand new diagnostic machine that is suppose to be the best in town. They will let me use it for free. (they also let me use their lifts for free )Would the opti show up on a scan.
Old Apr 2, 2004 | 10:19 PM
  #23
95BlackTA's Avatar
Originally posted by david97gsxr
hmm....because my car has a small stumble at idle. the rpms drop from like 700 rpms to 500 rpms. just every once and a while. when it drops it makes a whistling noise.
if i give it just a little bit of gas, to bring the rpms up to 1200 rpms or so it completly clears up.
i already replaced the IAC, and i'm about to do plugs/wires when i install my headers.
it's hardly noticable at all......i was just wondering if my problem was the same as yours.
Mine does that, and I have an intake manifold leak. Check the back of your intake and see if theres any oil at all..rub your hand behind it, and i bet you it will come back oily.
I still havent fixed mine yet...i need to.
Old Apr 3, 2004 | 11:05 PM
  #24
94NDTA's Avatar
What is the correct operating temp of the LT1. It seems like it waits unstill it is over 210 to start stumbling (I thought it was 190 before) My Thermostat didn't open until about 225. It was stumbling the whole time, but when it brought the temp down, it ran fine. Could it be a bad Thermostat?
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
