i guess you guys were right may not be opti im so lost want to sell???
went in to shop monday and the 1,3,5and 7 cylinders would not missfire but after the car ran for little bit it started to missfire but some of the missfires were in the 4 and 6 cylinders and the 1 3 5 7 cylinders were not nearly missing as bad and my surge came back when it shifts into overdrive its almost been a month and no luck im so pissed at my car i almost want to sell it but i care about it so much it just makes me want to fix it even more so im kind of broke right now cause well my car and all so i will mail 50.00 bucks to who ever can help me eliminate this problem i will help the best i can with the info and stuff thanks everyone for the help. randy
How does the car's PCM act? Will it let the scanner read codes? If the opti is good, I would guess that is your problem. Key word is guess. If EVERYTHING ignition checks out ok, that and your injectors (again, not likely) are about all that's left that could cause what you describe.
Or maybe you have a bare wire/short someplace?
Good luck with it.
Dave
Good luck with it.
Dave
Wires...
Maybe your wires are arcing across one another, causing a misfire. How are they routed and what kind are they? I would get a second set of eyes to check them out. Check the coil wire too, just to make sure it and the coil post look OK.
Keep working on it, you'll find it.
$50
Dude,
Buy a set of accel wires from advance or autozone, put them on and send me a money order.
Also unplug the battery while you're replacing the wires, that way the PCM will reset those BLM's from trying to make the car run well with those old wires.
Also, don't replace the wires without putting another $10 on some Autolite 106 plugs. And please, get all 8 of them and don't try to replace only the bad ones.
D Moss
D Moss
Have you taken it to a shop recently? You said you have Taylor wires and AC plugs and an MSD coil. But you didn't know how they were routed. Did you have a shop do this work for you? If so, was this problem going on before these items were replaced?
TAYLOR wires
I bought some of this junk once.
If you look at some of my previous threads, you'll see the nightmares that I had with Taylor wires. Never again. I've never in my life had another brand of wires to where the fire would arch through the insulation in the MIDDLE of a wire to the block.
I promise, MY OATH: I will never buy another set of Taylor wires.
Anyway, some people have had good luck with these wires. Have them checked out and hopefully you'll get this figured out.
D Moss
D Moss
