I dont understand this light....Water pump install Schematic question
Old Aug 6, 2003 | 08:39 PM
  #16
94formulabz's Avatar
Originally posted by 94Sleeper
The only thing off of the relay switched output should be the pump. The 5.6k resistor should really be hooked up to the same switched power as the rest of the monitoring circuit. The 5.6 and 100 ohm resistors are just a voltage divider to fix the comparitor threshold.
That seems so darn obvious and makes perfect sense when you say it, i don't even know why i was thinking about R5.6.
I'm installing my harlan shiftlight now and just came in to double check how many extra wires to run through the dash. This also seems obvious but i guess i should double check and ask since i didn't even read that circut correctly earlier. just 1 for the buzzer, 1 for the LED, and 1 for my manual switch for a total of three right? Nobody answer that if i am wrong, it'll be too late anyways
Old May 10, 2004 | 01:47 AM
  #17
blown383's Avatar
Any updates on the kits?
-B
Old May 10, 2004 | 12:28 PM
  #18
I never heard another word from him about the kits. I've been running mine without any warning light. I pay such close attention to my gauges anyways. Plus, i'd definitly notice a drop in power from warming up
-brent
Old May 10, 2004 | 01:55 PM
  #19
blown383's Avatar
man...I wish my *** was that sensitive.
-B
Old May 10, 2004 | 02:32 PM
  #20
GetaZforgetGT's Avatar
Try PMing him.
The hard part is finding that .05 ohm resistor.
I built this circuit and it seems to work fine so far.
Old May 11, 2004 | 08:24 PM
  #21
94Sleeper's Avatar
The reason the kits never took off is a basic lack of interest. I had some circuit cards made and bought some other stuff but it didn't look like there was any real interest. I made a few kits for folks but I was only making about $20 a kit and it took a couple of hours each to assemble so I really didn’t pursue it.
If you need help building the circuit or if you want a circuit fabricated I should be able to help you out.
Old May 12, 2004 | 12:11 AM
  #22
blown383's Avatar
I would be intersted in making a circuit myself..but then again I would need specific instructions. Are there any instructions laying around? If its too complicated then I would rather buy one outright.
-B
Old May 12, 2004 | 09:46 AM
  #23
94Sleeper's Avatar
The only instructions are on my linked web page under current monitoring circuit.
If you are not really sure how to assemble the circuit I have fabricated some small printed circuit boards for this application. I also have all of the parts less the shunt resistors. I could assemble a circuit card and test it for you for $15 + shipping. The shunt resistor and LED will cost another $5-$6 from an electronics supply store (not Radio Shack).
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Brent94Z
Mar 21, 2002 04:44 PM
