I did something stupid...
Old Jul 13, 2003 | 11:47 PM
AndyCLT1's Avatar
I just got done with cam, clutch, and suspension work. I bought a programmed PCM from PCMforless and installed it too. Then, I decided to see if it made a difference. So, I put my stock PCM back in, but forgot to disconnect the battery. I realized this when I started the car and wondered why the ABS INOP and AIR BAG lights are on. I disconnected the cattery and put the PCMForless PCM back in. Still same lights on. I checked all the fuses to see if I may have popped a couple, but of course they're fine so it's not that easy to fix. Any ideas on what I blew up before taking it to the dreaded dealer?
Andy
Old Jul 13, 2003 | 11:49 PM
madwolf's Avatar
Check this ground connection and make sure it's tight and makes good contact.
Old Jul 14, 2003 | 01:01 AM
scoobysnax83's Avatar
I can't offer much help... But I give you major credit for coming out and saying, "I did something stupid." Atleast you were honest. But don't feel too, bad. Whenever we get a new toy we want to see how good it is. Thats any easy mistake to make.
Old Jul 14, 2003 | 01:17 AM
revtime's Avatar
I am getting the same 2 lites after my header install.
I did install a LT4 KM but the battery was out of the car.
I am going to check that ground cause I took it off before to clean around it and maybe that is my problem.
Thanks to Madwolf for pointing this out.
Old Jul 14, 2003 | 01:22 AM
Rich_z28's Avatar
Also clean and check all of the connections in the little red box on the passenger side fender well. I had the same 2 lights, was told to clean all of the connections in there and see what happend. So I did and it took care of the lights. Don't worry man, we all brain fart once in awhile. You can't always be perfect.
Old Jul 14, 2003 | 01:54 AM
turbo_Z's Avatar
well nobody said this yet and it will make you feel better. pulling your PCM out without disconnecting the battery wont cause the problems you are experiencing. i got the same lights after my header install and it turned out i for some reason, still unknown to me, unplugged one of those connections at the ABS junction next to the fuse box.
Old Jul 14, 2003 | 02:01 AM
revtime's Avatar
This is cool, now I don,t think my junk is broken I think something just got unplugged or one of the wires or grounds is loose.
Thanks guys.
Old Jul 14, 2003 | 10:41 AM
AndyCLT1's Avatar
Thanks guys. I disconnected all te ground wires and cleaned then up. No lights! You guys rule!
Andy
