I called Comp Cams to get info and...
Old Dec 22, 2004 | 11:44 PM
  #16
96M6's Avatar
Re: I called Comp Cams to get info and...
Got a few question about cams also on Lt1's...do you have to change the heads if your gonna change the cam or just recomended?
I will soon be doing roller rockers(Gold Crane 1.6) got them at a good price so i jumped on them..but then realise, since im there might as well do a cam.
But in the future I would like to go S/C...so from what ive been reading, i need a 'blower cam' for maximum power and obviously i don't wanna buy a cam twice...any suggestion on a particular cam?
Btw what do the number stand for? eg:265 Dual Energy?
Old Dec 23, 2004 | 12:57 PM
  #17
SStrokerAce's Avatar
Originally Posted by stereomandan
Thanks Bret. I guess I had a different idea of how they worked. They had them showcased on Hotrod TV, and I swore that's how the Comp Cams rep described them. This wouldn't be the first time I've been wrong though.
Must have been the mass that he was talking about.
Dan
Dan,
Not a problem. There are a lot of reasons why they are good springs and there is some odd information out there on them but all in all they are good pieces. Thanks to spring wire purity levels that we have today it's not a bad thing to run a single spring anymore. Duals do give you a little extra protection but that does come with added mass and usually lower quality spring material unless you REALLY want to spend money.
Bret
Old Dec 23, 2004 | 12:59 PM
  #18
Nopw you don't need to change the heads, just the valve springs to go with the rest of the valvetrain.
A blower cam is much different from a NA cam. You could have a cam that does both but not both well.
Cams aren't cheap but realtive to a good blower setup they are. $260-$350 for a cam which makes the motor work optimally for your setup is really not a bad way to go.
Bret
RUENUF
May 25, 2016 08:10 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Elcojoe
Nov 17, 2014 10:27 PM
