Hydra-Rev kit?
Old Jan 25, 2004 | 02:29 PM
Z28RV's Avatar
Hydra-Rev kit?
can i put one on my engine, mods are listed below, or do i need an aftermarket cam? can it operate on a stock heads and cam car? and wht kind of gains should i expect with this Hydra-Rev?
Old Jan 25, 2004 | 02:35 PM
FacelessZ's Avatar
HRK is a sort of safeguard against valve float...which most likely won't occur with a stock cam or stock rockers...it actually works along with the lifters...
Old Jan 25, 2004 | 02:39 PM
FacelessZ's Avatar
Sorry no big "100 HP gains" like the site says...people with aftermarket cams and rockers typically don't even see it...the HRK would make most sense with a set of 1.6 SA rockers and stock lifters so they can take the correct measures against minimizing valve float
Old Jan 25, 2004 | 03:32 PM
Josh-'04 GTO's Avatar
HydraRev is a waste on a stock cam car. To be honest, cars already come with a good valve float preventers....they're called valvesprings! As long as you have the right valvesprings and don't overrev, you shouldn't have issues with valve float.
lt1xondeck
Mar 18, 2016 07:22 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
