How's the clip on the A4 shift knob come out?!
Old Jun 20, 2003 | 04:35 PM
GrdLockV6's Avatar
How's the clip on the A4 shift **** come out?!
Argh, I can't get that crappy clip out! Is there anything to do besides grab it with a pair of pliars and pull? It just won't come out. I snagged it a bit with some damned vice grips and still couldn't pull it out, wtf. I need to take the **** off so I can take off the console to cut a piece.
Old Jun 20, 2003 | 04:38 PM
Shockwave's Avatar
Lounge Moderator
Moving to LT1 Tech. Please use the Technical Forums for Technical F-Body Questions.
Craig
Old Jun 20, 2003 | 04:42 PM
Derrick Redd's Avatar
Just put it in neutral and pull the clip out. Then pull up on the **** and it should come off.
Old Jun 20, 2003 | 05:07 PM
TobyZ28's Avatar
Sound sooo simple doesnt it.. I've tried for 2 years to get the freaking clip out, i swear its welded in there or something, i can't get it out either...
Old Jun 20, 2003 | 05:55 PM
I've Never had any trouble using a small flat blade screwdriver to pry it out.
Old Jun 20, 2003 | 08:53 PM
revtime's Avatar
Quit being a girly man about it and just pry it out of there.
I,ll make a deal with you guys, you come over and put my BMR torque arm on for me and I,ll get those clips out for ya.
Old Jun 20, 2003 | 11:35 PM
TobyZ28's Avatar
*pulls out the hacksaw*
Old Jun 21, 2003 | 12:24 AM
Zepher's Avatar
I've never had a problem pulling the clips out.
I do have a problem with the clip not going back in all the way with the 4th gen Camaro shifter I installed into the Formula.
Might be a longer clip on the 4th gens.
Old Jun 21, 2003 | 12:25 AM
Rich_z28's Avatar
All I've ever had to do is use a small flat blad screw driver.
Old Jun 21, 2003 | 12:42 AM
BadRag's Avatar
Use either a flat screw driver or niddle plyers to remove the clip/staple and should twist off
BadRag
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
themex2002
Sep 2, 2015 03:47 PM
