how would i do this??
Old Aug 5, 2003 | 10:35 AM
Bobbys_97_Z28's Avatar
Question how would i do this??
im getting little puddles of oil under my car, and i located where it mostly was...its dripping off the opti....someone once said that it is most likely coming outta the wp drive seal. ok...if im going to do all this stuf by takin off my wp, im just gonna go ahead and buy a new opti...and a elec. wp(csi) what i want to know is...if i end up buying the elec. wp, i dont have to fix that seal in there cuz im gonna have to plug the whole thing anways right??thanx for all y our help
Old Aug 5, 2003 | 10:59 AM
IDOXLR8's Avatar
Your leak is more than likely coming from the crank seal located on your timing cover.
Old Aug 5, 2003 | 11:13 AM
how
i dunnoo...cuz the oil is dripping off the opti from high on top of it(well as far up as i can see) to the bottom, then its falling to the swary bar, then to the ground. but i dont think its coming from the crank seal, if it was, do i have to take the cover off inorder to put a new one on??
Old Aug 5, 2003 | 11:27 AM
IDOXLR8's Avatar
You would have to remove the balancer and hub in order to remove the gasket.
