How wide is a 245/50/16 tire??
Thats the stock size tire for Z28's with the performance upgrade from the factory...otherwise you got 235's with a speed limiter. It's an approx 10 inch wide tire...suitible for stock Z28's but after you start modding...you will be spinning them like crazy.
Re: How wide is a 245/50/16 tire??
Originally posted by ChevyTuffD.A.
I am not very good with tire sizes at all. So how wide is a 245/50/16 tire? Is that pretty wide or no??
Re: Re: How wide is a 245/50/16 tire??
Originally posted by Dave19yz28
its 245 mm wide (tread), 50 mm sidewall, and for a 16 inch rim. Those were stock tires on a z28 i believe. Go out and look at your tires, it will say on the side what size they are, that will give you a guide. I think the largest you would want to go on the 16 by 8 stock rim is 255 or 265...
Bails098
Aug 17, 2015 05:15 PM
Latronaxe
Jul 20, 2015 12:00 PM
