How well would this intake Work???
Re: How well would this intake Work???
Yeah thats him. That intake setup was with a Wilson 105mm elbow and a big ole TB along with some new ported AFR's from GTP. I don't think it was just the intake that did all of that.
As for the camshaft specs.... if I told ya, well you know the rest. I beleive sherman ran even less lift than that, like .560" on the intake, .525" on the exhaust with the same lobes and 1.5 rockers on the exhaust.
The 918 spring should work if you cut down the lift a little and shim them up, but I would even look at the larger beehives and shim them up. I know your buddy at Comp can hook you up with this, but even then there are some tricks with all these things that I'm sure they aren't using.
As for the blower, as long as you speed it up like that you should be golden.
Bret
Bret
Bret
Bret
Jul 4, 2005 05:00 PM
