How is Trick Flow head performance?
Old Mar 12, 2005 | 04:04 PM
BadCamaro's Avatar
Question How is Trick Flow head performance?
Wanna to know how is it performance and its quality? How much hp it gains?
Old Mar 12, 2005 | 05:13 PM
amean94ta's Avatar
Re: How is Trick Flow head performance?
its better to get your stockers ported with 2.02/1.60's the exhaust flows better but the intake sucks on the trick flows plus if your just adding the heads it will lower your compression and you will loose power. i got 278/230 out of my stockers and i think the numbers on the t/f were 245/176
Old Mar 12, 2005 | 05:23 PM
blind527's Avatar
I don't understand all this head/cam stuff with intake/exhaust lifting and all that garbage. Can someone clue me in?!
I wanna get a cam and heads. What is a good beefy cam? I don't understand what good heads are, and the 230/whatever for cam? I don't understand it.
Old Mar 12, 2005 | 06:01 PM
amean94ta's Avatar
ok i am ready to help figure out what hp or et you want to run and i will go from there to tell you what to buy also let me know if you want to run pump gas or race gas if its a street or race and how many miles a year you plan to drive it also where your located to suggest some shops to you
Old Mar 12, 2005 | 06:06 PM
blind527's Avatar
I want it to be in the low 12's as of now, maybe high high 11's. This will be a street car on pump gas. It has 60,000 miles on it as of right now and is an A4 97 Formula. I would like between 400-420 HP I drive a lot of miles per year About 15k
Old Mar 12, 2005 | 06:24 PM
amean94ta's Avatar
ok have your stockers ported by loyd elliot have the 2.02/1.60 manley race flow valves installed and use a cc 306 cam or gm 847 with 1.6 crane golds. that will get you where you want
Old Mar 12, 2005 | 06:35 PM
blind527's Avatar
Awesome, sounds good! How is this setup for daily driving? I go to Maryland and Deleware a lot But since you gave me that setup I supposed that is correct as I said I drive about 15k a year. Thanks man!
What about springs, lifters etc.? Does the cam I get from him have everything? What is the manley race valve, is it included with the heads then?
Old Mar 12, 2005 | 06:41 PM
amean94ta's Avatar
just tell him what i told you or he will already know and quote you a price he is a supporting vendor
springs he will pick lifters you dont need with only 60k
Old Mar 12, 2005 | 06:45 PM
blind527's Avatar
Awesome, thanks! I'll def. check that out
BTW...I'm not sure about installing this stuff by myself, as the downtime will be pretty extensive. I don't have the correct tools to do a mod like this, so I will probably have a dealer or speed shop to do it. I can't seem to find any speed shops in Richmond, VA.
I don't think I have the right tools, as I only have basic sockets/ratchets etc.
Old Mar 12, 2005 | 07:56 PM
eagleknight97's Avatar
Im pretty sure that either a dealer wont do any of that work and even if they do, they would tear you a new one while they do it. Work hard on finding a speed shop or quickly befriend a local mechanic and maybe he will help you out.
Old Mar 13, 2005 | 02:43 PM
BadCamaro's Avatar
any one?
Old Mar 13, 2005 | 09:07 PM
amean94ta's Avatar
not much waste of money unless you want to build a 396 blower motor and have them ported they aint good
RUENUF
May 25, 2016 08:10 PM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
