How To Tighten Down Rockers
Old Mar 7, 2008 | 03:40 PM
z28camaro1090's Avatar
any info on a easy way to tighten the rockers on my car would be helpful thank u
Old Mar 7, 2008 | 03:43 PM
greenmachinedriver's Avatar
i think shbox.com has a good wrightup on it. i prefer to do it with the engine not runnibg. basicly the idea is to adjust the rocker to zero lash and then add a small amount of preload.
Old Mar 7, 2008 | 03:53 PM
ss.slp.ls1's Avatar
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Mar 7, 2008 | 03:57 PM
i also have a question with this could this be causing performance issues them being loose??? i can hear them real loud and if i rev to about 4k it sounds like it a rocker hits the valve cover
Old Mar 7, 2008 | 04:02 PM
ss.slp.ls1's Avatar
It could cause a performance issue, and the rockers will tick/clatter if they are too loose. Exhaust leaks can sound like loose rockers just so you know. Adjust the rockers according the link and see how it runs/sounds after that.
Old Mar 7, 2008 | 04:09 PM
i think that might be the problem cause like i can see the gasket on the header is messed up.. and its been failing emission which would make sense cause its before the o2 sensor.. but a mechanic laughed at me when i asked him that.. i was like im pretty sure that sounds more likely but he was like ur valve train sounds tired
Old Mar 7, 2008 | 04:48 PM
ss.slp.ls1's Avatar
Well if you have a bad exhaust gasket than can cause a lot of noise too. I would adjust your rockers, change the gaskets, and then see if its still making noise.
Old Mar 7, 2008 | 04:51 PM
ok im gonna go with the header gasket first and see if it changes it and then do rockers. because it seems liek the gasket will take less time and i dont have a garage to do it in and its still kinda cold out lol
Old Mar 7, 2008 | 08:50 PM
2000GTP's Avatar
Is it a ticking noise or a loud metallic banging? A loose rocker will not only lead to a performance decrease, but can lead to bigger problems.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
