how to test fuel injectors?
Old May 2, 2005 | 03:43 AM
97silvermaro's Avatar
goin through a swap right now with some problems i might add one of the mods are bigger injectors that were installed between the swaps... how can i test to see if they are actually pumping fuel? thanks
Old May 2, 2005 | 05:45 AM
slopokrodrigez's Avatar
Re: how to test fuel injectors?
You can check them with an ohm meter to be sure the coils are intact. Then check the signal with a noid light. As long you have fuel pressure, you have to assume they are opening. You could have them flow tested by a pro.
If we knew what year you had, we could suggest another way to test them. On OBDII cars, you can hold open or shut off individual injectors while the car is running with a scanner.
Old May 2, 2005 | 10:57 PM
95lt1
AdsoYo
May 2, 2018 03:21 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
