How To Test ECT?
Old Apr 16, 2004 | 04:26 PM
93Z286Speed's Avatar
How To Test ECT?
I need to test the ECT for the guage on the side of the block near the #1 plug. I had it break off last fall while doing my header install and put a new one in scince the heads and cam.. I havent street drivin the car or had it running for longer then 2 mins. So im not sure if its working or not. But my Tstat housing is real hot along with my alternator .. But anyway how can i test this to see if its good?
Im asuing the guage works off resistance or voltage, so can i apply voltage to the conector in some way or apply resistance so i can see the guage sweep the dash
thanks for all the help
Old Apr 16, 2004 | 04:47 PM
disco192's Avatar
Get a multimeter and a thermometer. The resistance will change inversely with temperature (higher temp, lower resistance):
It should read something like this:
T* (F): Resistance:
212 177
194 241
176 332
158 467
140 667
122 973
113 1188
104 1459
95 1802
86 2238
68 3520
50 5670
41 7280
32 9420
(baiscally you can check it with an ice cube and boiling water)
Old Apr 16, 2004 | 05:46 PM
T* (F): Resistance:
212 177
194 241
176 332
158 467
140 667
122 973
113 1188
104 1459
95 1802
86 2238
68 3520
50 5670
41 7280
32 9420
isnt that the sensor by the water pump? or are they the same?
Old Apr 16, 2004 | 06:14 PM
Testing
Old Apr 16, 2004 | 07:12 PM
awesome awesome awesome, i musta over looked that!
Is there anyway to check if the guage is working properly?
Old Apr 16, 2004 | 08:13 PM
disco192's Avatar
There are 2 temp sensors in your car. One goes to the guage in the dash and one goes to the PCM. The one on the water pump goes to the PCM, the one on the drivers side cyl head goes to the dash guage.
Old Apr 16, 2004 | 08:27 PM
correct the one im worried about is the one that goes to the guage, the one on the drivers side of the motor
as stated in my first post
thank you for the help though
KYWes
Jun 14, 2022 06:52 AM
karpetcm
Aug 14, 2015 03:02 PM
force10
Aug 10, 2015 08:30 AM
detroitmuscle
Jul 31, 2015 04:21 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
